1 - 20 of 55 Posts
2011 SRX Luxury
2011 SRX Luxury
Jimmy,
will you add "The Captain's" led light thread to the DIY's? Also, add the cabin filter DIY to the list.
14 ATS AWD 3.6L Performance - Son of a Gun Grey Metallic
2012 SRX Performance FWD
If you want to replace your glove box light with an led, simply take a plastic edge tool and pry the light down and toward the front. A dowel will need to back out of a hole (this is the switch to turn the light off when the door closes and pushes it.) Take your plastic edge and push the bulb out from the back of the socket because the bulb will be hot. Replace bulb with a small 194 led and reinstall light assembly. Enjoy your crisp clean led light!
2014 S550, 2018 XT5 Platinum, 2019 XT4 Sport :)
I did a post on a detailed Battery ( Type 48 AGM ) last year with photos. This week I added a bunch of info on xfer fluids 2010 srx under DIY. Would be nice to get them here for everyone else. The battery can also be used on the Escalade.
Just remembered I also did a complete write up with photos to do a MOTIVE brake flush on the SRX last summer. How can we search them and post relevant info here...?
1 - 20 of 55 Posts
