Here's my costs to rebuild an electronic Qjet:
Rebuild kit $45
Float $10
Carb cleaner $10 (two spray cans @ $5 ea - I use the spray cans because the little tube lets me spray into passageways)
Gas filter $5
Air filter $5
As for tools, if you plan on doing any work on your car at all, you should already have a dwell meter, timing light, and vac gauge. I wouldn't count these towards the cost of the rebuild. The special EQjet tools are nice, but not mandatory. I was able to adjust the M/C solenoid screw with a pair of long needlenose pliers. The factory service manual gives the gauge dimensions of the special gauges, so I made duplicates with bent wire and tubing. Since that rebuild, by the way, I've acquired a complete set of the special double D tools, the gauges, and the choke angle gauge all on ebay for cheap.
You are correct about testing the M/C solenoid and the TPS prior to disassembly. Mine were fortunately fine, but if necessary, wrecking yards around here (Northern VA) are full of B-body wagons with 307s and EQjets. You could grab a selection of TPS and M/C solenoids for just about nothing.
Note that I did spend $8 at NAPA to buy the terminals and necessary to fabricate a jumper harness to let me check the TPS voltage. Since then I've gotten a complete OTC Genysis electronic test tool (mainly for my 99 Chevy truck) that allows me to plug into the ALDL connector and read all the sensor outputs. You can find OBD I scan tools on ebay for cheap also.
Total cost to me: $75 (plus $8 for the terminals)
Knowing the carb is rebuilt correctly and satisfaction of a job well done: Priceless.
Rebuild kit $45
Float $10
Gas filter $5
Air filter $5
