Does anyone know if the factory mesh XLR-V grill assembly directly fits the 04-05 (non-mesh) models.
What I'd like to do is order a factory replacement XLR-V grill and swap it out for the standard one.
It looks like the "Grille Assy XLR-V" can be had for under $400 from a quick online parts catalog search. I would want to verify though if that is the complete assembly (frame, mounting, etc.)
Thanks from this newbie!
All Sold now driving 2018 CTS Cadillac 09 CTS and 97 Seveille STS recently sold a XLR
I recently swaped out a V grill from automotive concepts took about an hour. When I was at Bowling Green I examined the V grills on V cars it looks like the end of the hood is different where as the AC one is stainless and glues on. I actually like the AC one a little better because of the Stainless vz chrome since the Stainless is poslished you canlt tell the difference. The real difference is the AC one has a black metal backing behind the Cadillc emblem where as the factory one is all mesh. Its more of a personal decision I guess. Good luck either way. Oh ya I did not install the bottom center full stainless grill as I like the blacked out look across the entire bottom. jim
Cadillac Technician
none
I am almost sure I remember reading some posts where a fellow figured out that it wasn't possible due to the differences in the hood and the front piece.
Do some searching.
I don't have a V here to look at right now to double check.
Sedan de Ville, CTS
Will, You have disappointed us. We thought you knew everything about everything. No, that was Koz.
Keep up the good work.
Cadillac XLR
The V grill will not fit the XLR. The front of the hood is different. You will have to buy an aftermarket instead of a GM V grill. The aftermarket grills are more, around 5 hundred. Over priced if you ask me.
