I had the same problem with my '97 Eldorado. I don't know if your '95 SLS has the same computer, but this is what I did to activate my alarm:
Go to the section in the FSM on the Instrument Panel Cluster
Go to the Instrument Diagnostic Center Section
Look at the section "Display Diagnostic Codes" and go to IPC Override Displays
In the IPS01, increment the display to 13
This activated the alarm system on my Eldorado. Be sure and read the FSM carefully because if you mess this up, the IPC may be placed in an unrecoverable state. The IPC will have to be replaced if this happens. If you read the FSM carefully and follow instructions, it's a piece of cake! Let me know if you need further assistance.:thumbsup:
