1 - 2 of 2 Posts
2005 CTS-V Mallett No. 05V011
I need some help with removal of all four upper window trim pieces and the driver's side B-pillar piece. Anything specific from the service docs would be appreciated along with diagrams etc.
Thanks.
Steve
´05 CTS-V Stealth Gray
Here:
http://www.cadillacforums.com/forum...eneral/288730-replacing-door-window-trim.html
Or this text:
No clips at all. Steps below.
Quite easy. First thing put window down, remove door panel by removing two screws hidden behind armrest and unclipping handle trim. After that pull seal out from channels inner part leaving dangling. Remove two 10MM bolts holding mirror in place. On backside of wide trim piece there will be 3 screws remove them. On inner channel side there will be 2-3 aswell. On very top corner there is one hidden you pull back upper weatherstrip lightly and unscrew. After that on you can follw upper channel underside there will be screws all the way down until you reach mirror. You can then remove that upper trim. Once out the weatherstrip can be swapped over if needed to new trim. Quite easy just time consuming for removing once piece of trim
Good luck and best regards,
Ronald
1 - 2 of 2 Posts
