I took off my front strut assembly to investigate bumping sound on the front left.(already disconnected the sway bar, wasn't that).Once I got the shock out I was pushing it down to check it out. I pushed it down against my workbench and when it got to the bottom the seal exploded and covered everything in oil :-( . I've never had one do that, are you now supposed to bottom the shock out?
After I cleaned up that mess I checked out the lower control arm. It is very squeaky as I move it up and down. The front bushing also doesn't hold a perfect shape when fully down. Can you replace just the bushings?
