1 - 8 of 8 Posts
2006 Stealth Gray CTS 3.6VVT 6MT
I have a decently loud rattle coming from my exhaust.
It sounded at first like a loose heat shield but after getting under the car there's nothing visibly loose. If I bang on the passenger side of the exhaust it almost sounds as if there's something in the cat rattling around. Anything else I should look for before I take it into the dealer (or start taking things apart)
hasn't thrown any codes, drives just fine, just sounds like a junker!
Thanks for the help
CTS 03
If you have warranty, take it in. I had a bad flex joint on mine with no warranty. i took it to Midas and they had to weld in a new flex joint, $160.
2003 CTS
Mine was a braket that is basicly under the front seats. It holds the heat sheilds together, between the two pipes. It is a very inexpensive part and it is only two bolts
The Mighty Kael, 2004 Black CTS, Every Option
could also be a chunk of the car rattling around.
if so you will get a light on in a few days.
Where exactly? Did the sound sound like it was coming from under you wen you had the door open? Ive had a rattle there for a year and have gotten used to it and never bothered to fix it but if its cheap and expensive.. sure! Its a low rattling sound you hear when accelerating from a stop. once the car gets moving and the engine gets louder, you cant hear the sound. Is this the same thing u were experiencing before you fixed it?
I seem to be experiencing the same type of problem. When ever I start the car and it is idling there is a very loud rattling noise coming from under the car. When I press the gas or I am driving the rattling noise goes away. It is only present when the vehicle is idling. I have a 2003 CTS. I though that it might be the Catalytic Converter but I am not sure. If it is do you guys know where I can find one? I tried searching online and couldn't find anyplace that sold them.
Thanks!
03 Redline CTS Lux Pkg
I had the rattling noise as well. Turns out it was a busted bracket for the exhaust that was rattling around.
1 - 8 of 8 Posts
