1 - 20 of 37 Posts
09 CTS-V
Looks nice especially the third brake light/spoiler.
CTS-V 2009 White Diamond, 996TT Silver, G35 Coupe 6mt, M45S
looks sweet. got pic of them lit up?
Regular Lights on, Brake Lights on and Brake lights in the sun.
Regular Lights, only the vertical clear bar in lit up.
T
Guest
I too like the original better. Almost looks cheap, ie ricey. Sorry, not trying to flame you. If you like them, good for you.
'09 CTS-V
My car comes like that from the dealership, the Vs here are assembled in Austria, and turn signals HAVE to be amber and not a flashing red as standards require it. I'd like to note that the spoler/center light is red on my car, only the sides are clear. It might look weird in pictures, but they look good in person.
CTS V series
Here's some pictures of the european style tail lights on my Diamond White.
Got them of ebay. GM Part# 19211989
nice, definately gotta take of the "CREST" of the top of you V imblem. Have you thought of painting the piece between the exhaust and also the front piece on your front spoiler? I did and man what a diffrence. Make sure a good painter does it if not its gonna look like crap.:bighead:
Discussion Starter #12
You're not hurting my feelings. I just wanted to try something different. When I found them for a reasonable price, i figure i'll give it a try.
The tail lights are actually identical to the red ones, except the outer lens is clear instead of red. The original CTS-V 3rd light is different from the standard CTS 3rd light. The V is all red, whereas the regular has a black rim around it. Also, this clear 3rd light has a gray rim around it.
No amber in the lights, so the're different from the actual european issue.
I find that the original red 3rd light is actually more pronounced that this clear one. But if I add a spoiler...
And they're easy to swap out,
Hans.
09 CTS-V, Radiant silver, Loaded, Auto
I hate when dealers put their damn emblems on cars like that, especially over the V that matters! Cool post.
CTSV 09
hello
my car comes like that from the dealership, however id like to note that it seems ricey on the OP ride because for some reason there is too much red visible inside those tail lights...mine is clear all through and looks 10000x better than that
weird :))
2018 CT6E, old: 2014 XTS Vsport, 2005 CTS-V, 2004 CTS-V.
Looks very Opel'ish as will the new Buick rear lighting. :)
Norm
jwa999,
The export taillights I had on my 07 STS-V were similar to this. They were clear, but they had red when braking and amber when signaling to turn.
Also, did you get all 3 lamps with one GM part number? There should be 3 separate GM part numbers for this set-up.
Were they plug and play or were any modifications necessary in the wiring?
I would like to get the actual european taillights with the amber in them. Anyone have the GM part numbers for the true GM export taillights with the amber portion in them as well as the export 3rd brake light to match?
SG
Discussion Starter #17
cts v 2009
jwa999,
SG
i have euro lights in my car as im living in dubai. and have gulf specs car. are you willing to exchange? im interested in the red as i have a red color V
1 - 20 of 37 Posts
