My cluster does not work all gauges don't work even the messenger bar does not work I can't even tell if my truck is on D or N buy the back light work so at night everything is visible buy the gauges and messenger bar still does not work could it be a fuse sensor can someone give me some help thank you
I would check your fuses first. I would think it would be highly unlikely that your whole cluster would go out at the same time.
2015 Escalade and 2018 CTS-V
If fuses are good, Check the headlight switch. You can push on it or try and move it around a little to see if it comes back. Could be a bad switch. Otherwise it's probably just a bad cluster.
08 escalade
Fixed blue needle flashing replaced cluster instantly. Worked jus goes show cheap american product replace battey thats cheap then it burns out cheap made cluster
