1. Why are some 2007 base prices for this vehicle $58990, and others I see more recently $59640 (both excluding destination).
2. I have read every single thread about this wind noise---is realligning the door a definite fix now? I do not want to buy a 2007 model with this problem if there is not a definitive fix. I figure you guys would know more than calling cadillac.
3. Will the 2008 models have this wind noise already fixed?
4. On the 2008 models, there is the "ultra v8 collection package"...with a small note saying you can substitute in the 18" wheels for the 22"---but there is no mention of how much money that will save off the package...anyone know?
Thank you very much.
Perry
2012 Escalade, 2014 SRX
On the Cadillac web site the base price is $60,540 for an 07' ESV, if they were built before any price increases throughtout the year there would be a price difference on the sticker. The 07's door problem is NOT fixed, I have two 07' Escalade's and have very little wind noise from either one, but I have been in some that are very bad. I hope it's fixed by 08' but have yet to read anything to that. :)
Discussion Starter #3 (Edited)
the cadillac web site msrp that you mention includes the destination of $900.
so, there were increases in price over the 2007 year??
2008 Cadillac Escalade ESV
6K10906 AWD 4dr
VEHICLE SUMMARY: Supp
Base Vehicle: -
Total Options: -
Advert/Adjustments: -
Destination Charge: -
Total Price: $56,935.77
VEHICLE SUMMARY: MSRP
Base Vehicle: $59,710.00
Total Options: $0.00
Advert/Adjustments: $0.00
Destination Charge: $900.00
Total Price: $60,610.00
Effective Date: 6/29/2007
STANDARD EQUIPMENT
<<< NOTE >>>
**ALL STANDARDS ARE 2008 UNLESS OTHERWISE NOTED**
<<< MECHANICAL >>>
Engine, Vortec 6.2L Variable Valve Timing V8 SFI (403 hp [300.5 kW] @ 5700 rpm, 417 lb-ft of torque [565.4 N-m] @ 4300 rpm)
Transmission, 6-speed automatic, heavy-duty, 6L80E, electronically controlled with overdrive and tow/haul mode
Throttle control, electronic
Cooling, external transmission oil cooler, heavy-duty air-to-oil
Transfer case, AWD, electronic automatic system, full-time, "always-on" all-wheel drive
Trailering equipment, heavy-duty, includes trailering hitch platform, 7-wire harness with independent fused trailering circuits and 7-way sealed connector
Differential, heavy-duty locking rear
Rear axle, 3.42 ratio
StabiliTrak, vehicle stability enhancement system with Rollover Mitigation, includes disable switch
Traction control, all-speed, electronic
Battery, heavy-duty 600 cold-cranking amps with rundown protection and retained accessory power
Alternator, 160 amps
Recovery hooks, 2 front, frame-mounted, recessed in front fascia
GVWR, 7400 lbs. (3357 kg)
Suspension, front independent, SLA, coil over shock and stabilizer bar
Suspension, rear 5-link coil springs
Suspension Package, Road Sensing, electronically controlled shock absorbers
Automatic level control, heavy-duty, air
Tires, P265/65R18, all-season, blackwall TL AL2
Tire, full-size spare, P265/70R17-113S blackwall
Wheels, 4 - 18" x 8" (45.7 cm x 20.3 cm) 7-spoke aluminum (Requires (QXK) P265/65R18 all-season, blackwall, TL AL2 tires. Includes 17" spare.)
Tire carrier, lockable outside spare
Steering, power, rack-and-pinion
Brakes, 4-wheel antilock, 4-wheel disc, VAC power
<<< EXTERIOR >>>
Luggage rack, roof-mounted with chrome accents
Luggage rack center rails
Moldings, color-keyed bodyside with chrome accents
Fascia, front, body-color
Fascia, rear, body-color
Assist steps, Black with chrome accents, mounted between front and rear wheels
Headlamps, High-Intensity Discharge (HID) with (T74) Twilight Sentinel and flash-to-pass feature
Headlamps, Twilight Sentinel automatic delay (Included with HID headlamps.)
Fog lamps, front rectangular halogen, integral in front fascia
Daytime Running Lamps, with automatic exterior lamp control
Tail lamps, LED illumination
Glass, Solar-Ray deep-tinted (all windows except light-tinted glass on windshield, driver- and front passenger-side glass)
Mirrors, outside heated power-adjustable, power-folding and driver-side auto-dimming, color-keyed, with integrated turn signal indicators, ground illumination and programmable to provide curb view when in reverse
Wipers, front intermittent, RainSense
Wiper, rear intermittent with washer
Windshield washer fluid system, heated
Door handles, chrome
Body, liftgate with deep-tinted liftglass, includes rear-window wiper/washer and defogger
Body, power liftgate
<<< INTERIOR >>>
Seats, front bucket with leather seating surfaces, driver and front passenger 14-way power seat adjusters, 4-way power lumbar control, independently heated driver and front passenger seat cushions and seatbacks (3 settings), 2-position driver memory and articulating outboard head restraints
Seats, second row bucket with leather seating surfaces, reclining with heated seat cushions (3 settings) and fold-down armrests
Seats, third row 50/50 split-bench with leather-appointed seating, 3-passenger, can be folded, tumbled forward or totally removed
Console, floor, with damped-door storage covers, large storage bin, analog clock, dual cup holders, rear seat audio and electronic climate controls and second row heated seat controls
Console, overhead deluxe, with reading lights and (UG1) Universal Home Remote (Includes sunroof controls when (CF5) power sunroof is ordered.)
Floor covering, color-keyed carpeting
Floor mats, color-keyed carpeted first and second row with cargo area mat
Steering wheel, color-keyed with wood and leather-wrapped rim
Steering wheel controls, mounted audio and cruise controls
Pedals, power-adjustable for accelerator and brake
Instrumentation, analog with speedometer, odometer, fuel level, engine temperature and tachometer
Driver Information Center, with programmable personalization features such as door locking and unlocking, a trip computer that contains trip odometer and individual tire pressure readouts, fuel information such as range, average mpg, gallons used and oil life and a message center that displays dozens of system messages such as low fuel, door ajar, security, seat belt reminder, low coolant and oil pressure low
Tire Pressure Monitor (does not apply to spare tire)
Windows, power with driver and front passenger Express-Down and lockout features
Door locks, power programmable with lockout protection and power lock for liftgate
Tow/haul mode selector, button located at end of shift lever
Cruise control, electronic with set and resume speed
Theft-deterrent system, vehicle, PASS-Key III+
Remote vehicle start
Rear Parking Assist, Ultrasonic with rearview LED display, audible warning and instrument panel-mounted shutoff switch
OnStar, 1-year of Directions & Connections plan. Includes the innovative easy to use Turn-by-Turn Navigation services which provide voice-guided directions (where available). Also includes Automatic Notification of Air Bag Deployment, Stolen Vehicle Location Assistance, Emergency Services, Roadside Assistance, Remote Door Unlock, OnStar Vehicle Diagnostics, Hands-Free Calling, AccidentAssist, Remote Horn and Lights, Information and Convenience Services, and Driving Directions (OnStar services require vehicle electrical system (including battery), wireless service and GPS satellite signals to be available and operating for features to function properly. OnStar acts as a link to existing emergency service providers. Stolen Vehicle Location Assistance and Remote Door Unlock success varies with conditions. OnStar Vehicle Diagnostics available on most 2004 MY and newer GM vehicles. Diagnostic capability varies by model. Turn-by-Turn Navigation requires ABS and is not available in certain areas. Visit onstar.com or call 1-888-466-7827 for system limitations and details.)
Universal Home Remote, includes garage door opener, 3-channel programmable
Climate control, tri-zone automatic with individual climate settings for driver, right-front passenger and rear passengers
Climate control, rear air conditioning
Climate control, rear heat
Defogger, rear-window electric
Audio system, AM/FM/XM stereo with CD/DVD/MP3 player, seek-and-scan, digital clock, auto-tone control, Radio Data System (RDS), Digital Signal Processing and 2 slots, top slot for DVD and CD audio/video, bottom slot for 6-disc CD and MP3 changer
Audio system feature, Bose 5.1 Studio Surround Sound system with 10 speakers
Audio system controls, rear with 2 headphone jacks (headphones not included) and controls for volume, station selection and media
XM Satellite Radio. With a wide variety of programming, XM has something to excite any driver. Whether you want to be entertained or informed, to laugh, think, or sing, XM has the perfect channel for you - coast-to-coast, and in digital-quality sound. 3 trial months - no obligation. (Available in the 48 contiguous United States. Required $12.95 monthly subscription sold separately after 3 trial months. All fees and programming subject to change. Subscription subject to customer agreement. For more information, visit gm.xmradio.com.)
Antenna, diversity
Cup holders, quad front, dual second row and single third row
Mirror, inside rearview auto-dimming with 8-point compass, outside tempurature display and OnStar controls
Visors, driver and front passenger illuminated vanity mirrors with extenders
Lighting, interior courtesy with theater dimming
<<< EPA FUEL ECONOMY RATINGS >>>
City 13/hwy 19 (6.2L engine/6-speed auto trans) (2007)
<<< SAFETY >>>
Air bags, dual-stage frontal, driver and right-front passenger with Automatic Occupant Sensing System (Always use safety belts and the correct child restraints for your childs age and size. Even in vehicles equipped with air bags and the Automatic Occupant Sensing System, children are safer when properly secured in a rear seat. Never place a rear-facing infant restraint in the front seat of any vehicle equipped with an active frontal air bag. See the vehicles Owners Manual and child safety seat instructions for more safety information.)
Air bags, head curtain side-impact, first, second and third row outboard seating positions with rollover sensor (Head curtain side air bags are designed to help reduce the risk of head and neck injuries to front and outboard rear seat occupants on the near side of certain side-impact collisions. Always use safety belts and the correct child restraints for your childs age and size, even in vehicles equipped with air bags. Children are safer when properly secured in a rear seat. See the vehicles Owners Manual and child safety seat instructions for more safety information.)
Automatic Occupant Sensing System, sensor indicator inflatable restraint, front passenger/child presence detector (Always use safety belts and the correct child restraints for your childs age and size. Even in vehicles equipped with air bags and the Automatic Occupant Sensing System, children are safer when properly secured in a rear seat. Never place a rear-facing infant restraint in the front seat of any vehicle equipped with an active frontal air bag. See the vehicles Owners Manual and child safety seat instructions for more safety information.)
Safety belts, first and second row belts to body, third row belts to seat, lap and shoulder all seating positions
so, it must be an early build 2007---and probably has wind noise. the dealer wont tell me where the car is so i can go see it of course.
i think i might wait for the 2008 to come out and just hope that there is no wind noise in the 08 models.
does anyone know that answer to question #4??? I would like to purchase that package option, but would also like to substitute the 18 inch wheels to save some money as the package says you can....but i just cant find how much money you save.
perry
