2013 SRX
2013 Performance. Getting error warning message: Remote not detected. This message is not consistent. Happens only once in a while. More times lately. Battery in FOB weakening? Any ideas on what could be the problem?
'14 SRX4 Premium
Probably a remote battery. Do you get the message with your other remote as well, or just one of them?
FYI in the event a remote is actually dead, place the remote in the indent inside the bottom of the center armwrest. There is an induction/detection system in there allowing the remote to be found even if fully dead and allow the vehicle to start.
Max
2010 SRX
Your DIC will give you a message if the battery in the remote is weak.
'remote not detected' can happen if you're in an area where signals are being blocked or the fob is stuffed in a winter jacket, etc.
If it happens once in a while, that's pretty common. If it's consistent, a battery change should solve it.
