2003 Cadillac DeVille
anothercaddiowner said:
Can someone tell me where i can go to find out what the code P109 is for ?
P109 = Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
Hey thanks 3dfx..Did you find that on the net somewhere? Are there more of the codes that are above 100 ?
I understand that some codes may be the same in number but have absolutely different meanings depending on what system i;e OBD 1 or OBD2...My cadillac is of the OBD1 style.
1993 Eldorado N* 4.6L..
Thanks again..
Thanks again..
No prob - btw its TWOdfx! :D
Even though your car is in the OBD1 era, the North* kicks out OBD2 codes. There are many more codes above 100, heres the site I used:
http://autorepair.about.com/library/ts/obd-ii/bl-obd-main.htm
2001 DTS, 2005 Mustang GT, 2010 MINI S
Po109
Hey...on a '93 PO109 is a memory reset code in the PCM. Its listed along with PO52. If your not having the computer reset...ignore.
Logan
