1999 sts northstar
Used to start in park, now sometimes only in park and now not at
All sometimes.
Check engine light comes on sometimes but codes all read good.
Please help.
2011 Crown Vic LX, 2009 Chevy Malibu 2LT
Check engine light comes on but all codes read good???
What does that mean?
You could have a worn/misadjusted PRNDL switch.
If the SES light is on he has DTC's. Dollars to doughnuts he's reading DIC messages and not DTC's.
Neutral safety switch.
2006 STS V8 1SF RWD
Definitely the neutral safety switch. Happened on my old '95 STS. Try putting the car in neutral and gently nudging the shifter towards reverse as you start the car, don't go all the way into reverse just towards it. This trick worked in the '95 for quite a while, eventually the problem fixed itself all together.
