Stock radiator?176, even in Arizona baby
i need to put my 160 T-stat in.. its been bouncing around in my back seat for like 3 weeks. you should come over and help me install it lol. i need somoe motivation176, even in Arizona baby
I had that car too ('96 Mystic), and I got the heating fix. Not because it really needed it per se, but mostly because I knew I would have it on the track and wanted the extra cooling capacity. Basically they would only replace your stuff if you hit a "thermal shutdown" or limp home mode. I can't remember how I did it, but I spoofed that to get mine replaced. Of course when they did that they tried to do some other "fix" to a wiring harness and screwed it up before my first ever road-course event, resulting in me taking my warranty-provided rental (4 door Chevy Cavalier with 3 speed automatic tranny) to Louden.On the highway I see coolant temps at 190-192*F. Driving around town I see 220-226*F. The highest I have seen it read was 235*F. I don't watch it all the time so I wouldn't doubt that it may have gotten higher.
My '96 Cobra was the first model year production with the 32V engine. Many people complained of cooling problems to where Ford supposedly upgraded the radiator and reduced the fin count on the A/C condenser to aid in cooling. Warranty would cover the cooling issue for '96 owners and Ford changed the design starting with the 1997 model year. Mine never received the 'cooling fix' due to some really dumb conditions that had to occur first before they would do the work. Anyway, many times I would see > 230*F+ temps for the 9+ years I owned it. Never did I have a problem. From that experience, I learned to worry about other things.
I can't say anything specifically for the V but running too low of a temp in a computer controlled engine can cause some self-tests to not perform which could lead to a check engine light. Other things may occur: emissions may go up (a concern if your state does the 'sniffer' test); engine may not go into closed loop quickly enough or at all leading to lowering gas mileage; engine may run rich lowering gas mileage and causing cylinder wash; thermal efficiency may be lowered too. I don't think operating a 180*F thermostat would cause any problems. A 160*F may be pushing it but since the radiators in these cars are the bare minimum, the engine may still see 190*F+ temps on a warm/hot day.
In the Caddy, I can't recall any moment that the analog gauge ever passed the 12 o'clock mark no matter what the digital gauge reads. I bet when the temp exceeds a value then gauge will move again. I can't stand "smart clusters."BTW - my car NEVER moves off of straight up on the analog gauge, which I believe corresponds to 190', no?
Are there instructions somewhere for installing the thermostat? I heard you have to drain the coolant and also heard that if you do it quickly you don't have to drain it.after my tune mine runs exactly at 192.. i have the 160 t-stat so hopefully i can get it down around 185, been kinda lazy to install it. i can tell you before i tuned the car it would be about the same as yours
i havnt looked around yet, i talked to a fellow member the other day that just installed the 160 and he said he lost about a gallon of dexcool. its easy to access so i am assuming its just like every other t-stat in the world. sucks that the dexcool is so expensive.Are there instructions somewhere for installing the thermostat? I heard you have to drain the coolant and also heard that if you do it quickly you don't have to drain it.
yea thats what i am gonna do. i have nothing to do monday so maybe i will tackle it thenA gallon? wow. If you get the concentrated stuff and mix it with distilled water it is much cheaper.
VERY common problem with these cars... I've had it for the last year, still unable to fix it... something wrong with the Elect. systemMy oil temps reached 300 yesterday after some hard driving for about 45 minutes in around 100 degree temps... worried me a bit... I'm going to change the oil just to be safe and look into anything else that can help...
I was tuning my car couple weekends ago with a friend and my oil climbed to 300 and the dings and whistles went off. I was doing extended pulls at high RPM for about 50 mins. I was also concerned, but the gauge in HP tuners said that my oil temps were about 20 degrees below that. I think that is just GM putting the fear in us so we don't seize our blocks.My oil temps reached 300 yesterday after some hard driving for about 45 minutes in around 100 degree temps... worried me a bit... I'm going to change the oil just to be safe and look into anything else that can help...
