My understanding is that the Olds swap would require the engine mounts from a Fleetwood equip with Olds engine. Not sure about the rest of the drive line, it would make sense to keep for GM to keep it the same. I had a Fleetwood 1988 and it still had 4bbl carb. You probably could make run but with out correct wiring not sure if all the info center would work. If u were going to put a 307 why not go the whole hog and put a 403, or 455. I would a donor Fleetwood that has all stuff u need to convert. The engine itself has the same outside dimensions and mounts 307,403,455. For the bigger engines I would change transmission to 4l60 or 4l80. Drive shaft length is easily adjusted. I did it on my 1 ton swapping manual to automatic. If u really want the Chevy 350, you could looked into 1990 donor car, it came with 350 Chevy and should have all u need to convert.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
Cadillac Forums is the perfect place to go to talk about your favorite Caddys including the ATS, CTS, SRX, Escalade, LYRIQ, Vistiq, concept and future Cadillac models.
