Engine Splash Shield
17K views 62 replies 16 participants last post by  cadillacmike68
I lost my rear engine splash shield under my car this week. Ran thru a large puddle (okay, it was a stinking flood and I didn't see it in time). All was well until I got up to speed on the eway. I heard a scraping sound but was in rush hour traffic. When I got home I saw it was trashed. Today I just removed it and said, "Screw it". Other than making life easier when I change my oil is there any benefit or detriment with it gone?
#45 ·
On another note. Back in January I went through Germany in my 1st gen CTS.
Lost the engine shield in the left lane above 200 kmh. The Ford Kuga just behind me got all the crap thrown at him.
Decreased speed waiting to take the next exit and was preparing myself for exchanging insurance info with the guy. But apparently he did not care.
Went into a service station and took the rest off the car. The plastic devices keeping the shield on are bound to fail at some point.
#47 ·
In these days of plastic fasteners (all cars have them) it makes sense to keep a few spares in your toolbox to replace as needed. The shield doesn't fall off if the attachment "hardware" is kept in good condition.
#48 ·
Hell, yes, you gotta put those 10 mm bolts back in place. Watch out if your dealer does an oil change. I have known of folks ending up with only two of those bolts installed.
I will probably not install a new shield on my car. Screw it, let's drive.
#51 ·
Even if the tech re-installs the bolts they probably over-tighten them and eventually the plastic wears through. I just did my first oil change recently and luckily both shields were still intact but I had to add washers to those bolts because the holes in the shield were enlarged. I've also replaced about a dozen broken or missing push fasteners on both shields. I bought a bag of them from Amazon. Unfortunately I received the wrong size (larger) and had to enlarge the holes a little to use them.
I will try to keep my shields intact and believe they are beneficial but if the second shield fell off I might just go without it. It would make oil changes a little easier and don't think it's absence would cause any serious issues.
#52 ·
OK this is the way to make all of this easy. Taking off the plastic under pan sucks. So, you get yourself a Fumoto valve and then you only have to loosen one side to attach a clear plastic tube. Flip the lever and the oil is drained. Flip the lever back to lock, change the oil filter and fill her up with new oil. Very easy and the plastic stayed in place!
#54 ·
I removed my rear shield exactly one time for an oil change and decided to cut a wrench sized hole in it for easy oil changes. So far no negative affects noticed. With that said I would prefer to have it in place.
I have used Fumotos in the past with tremendous success. They are great, albeit a little slow on the draining. That is the only downside other than if you offroad and break that thing off! As for the hole in the shield, I have read about that with some old timers as well, and it is handy, too. Both winners.
