as per my previous thread.....
still having continuous problems with my engine picking up rpm's...
then quiting....turning key both on and off...I hear nothing but a bunch of clicking....I have replace...the throttle body...and sensor....but when I move the wires behind the throttle body...the car runs good for awhile....I should also note...have had a full tune up done...wires, plugs,timing etc. etc.....
also I will say...I found a front exhaust manifold...and before replacing my cracked one...testing before putting on... this one had a small crack also...had it welded...by a top welder...is this a common problem with 4.5 engines....but would really appreciate...so help with engine picking up rpm's then quitting...as I said..
I turn the key off...and hear nothing but a bunch of clicks...turn it on and hear the same clicks...(car turns over...but will not start)
any help would be appreciated...
frankjb
frankjb
