It should only be the oil pan. I just mentioned earlier today how expensive the LLT motors are used despite being in excess of 100k miles and in need of a timing chain replacement before being practical to install. I left out an observation that will be of value to you since it appears you need a motor.
The LFX (2012 up 3.6L) short block is an excellent option, because where the LLT costs in excess of $2k used near me in FL, the LFX can be had for just under $500 with as little as 52k miles on it as long as I pick it up. I sourced them through ebay and narrowed the search down to within 100 miles of my zip. The LFX short block will probably bump your compression up from 11.3:1 to 11.5:1 which is the rating for the LFX, but that equates to a power bump over the previous stock motor. You would need to swap the LLT top end over to the LFX bottom end as long as the heads are in good serviceable condition.
Don't do this without confirming. I read where someone else actually did this. The only difference I'm aware of between the two short blocks is that the LFX has no valve reliefs for the exhaust valves in the pistons and that's apparently where the additional .2 compression points come from. Timing covers will differ for sure with front wheel drive versions, I'm not sure about the mounting bosses on the blocks which would have to be investigated. The rear wheel drive blocks should all be pretty close if not the same between the LLT and LFX after 2010
Take a look:
You can enter your zip over on the left hand side to check availability near your location.
