1 - 10 of 10 Posts
Vreaks -
A couple of weekends ago I changed fluids in the V. I meant to post this a while ago - but the oil life monitor was down to 7% (4,300 miles). What was curious is that when I went to reset it, well, it already had.
I didn't disconnect the battery or anything - but did let it drain for a good hour (filter and plug).
Anyone else ever see this?
If you tell me I'm freakin nuts, well, that's OK. It would help explain a lot of other things in my life :helpless:
04 ctsV platinum,maggied,rt cats,headers,corsa,stealth tune
No but i'm a:alchi:and the 80's were very hard on my short term memory.I have reset mine on accident.What was the question?
Discussion Starter · #4 ·
rp64ctsv -
the question was where are the pictures of those boobs in question on the DIC? Wait a minute...I got that wrong. The 80's, 90's, a 00's have killed my short term memory :alchi:
The real question is whether I reset it on accident (doubt it, because I've NEVER F'ed up anything in my life before, save for 31 days in September :histeric: )
I still want to see the pictures of the boobs. I like those IForge wheels so much - the boobs had better be good.
Discussion Starter · #9 ·
ctsvett said:
did you press ok when it warned you to replace the fluid?
Did you flash it with EFILIVE? The flash can reset the oil monitor if you do a full flash..
Reed
No EFILive flash at that time...and I didn't get a warning?
OK, we'll assume I'm crazy from this point forward :hide:
Banned
:rant2: No you can not run regular oil and you will void the warranty if they can prove that the engine caused the failure .
ualdriver said:
Are you guys running synthetic oil in your engines or just "regular" oil? You can run the engine on "regular" oil without invalidating the warranty, right?
1 - 10 of 10 Posts
