2002 DHS, 175 Kmiles
I have a 91 sedan deville. My wife went to start it four hours after it's last run and a new light along with bells and whistles came on stating the car was overheating. The Chilton manual stated that this switch goes to ground when overheating, but it doesn't state if this will stop the car from starting.
I took it to the shop and there was no spark, so when they removed the distributor cap the ignition coil was fried and broke when they touched it.
They congratulated me for having 187k on the original ignition wires!
Is the BCM computer smart enough to disable the ignition when it senses a overheating problem?
93 Fleetwood RWD, 99 Deville
No, it doesnt. It must have just messed up at the same time.
Blaze
Thanks for the reply. I had the ignition system pretty much replaced (cap,rotor,wires,plugs,coil,ignition module) and the car is purring like a kitten....$550 later. They didn't say anything about the idiot light, but it's off as well. They did not replace the switch.
This site is valuable resource.....I'll be back!
