1 - 10 of 10 Posts
2008 v the code came on last night after a 3 mile drive so I parked the car last night an when I went out today to have look, as soon I started the car the code came on fans blazing .What should I do? thanks Darren.
2013 OBM CTS-V Coupe
Discussion Starter · #4 ·
OK I get that I need a T-Stat . The car has sat for over a day and when I start it up for the first time the code a and fans are on . the engine is clearly cold. is there a code I need to reset?
T-Stat is stuck so the car thinks it needs to run the fans. Unless you are getting a check engine light no code to reset. The code on the DIC will go away after you change the T-Stat.
2017xts vsport platinum, 2011EXT, gt500
After a year of getting the hot ac alert I threw a check engine code then hadvthd tstst replaced.bought a new one but realized it was beyond my skill level. Had dealer do it
2009 CTS-V, 2008 STS-V
There is no code to reset if it's your thermostat. You can reset the car yourself, but you will probably find that the hot engine comes on again. It's around $25 for the part. It's something that can be done at home, if you're willing to put the effort into it. There's a ton of threads in here about the bad thermostat in the STS-V. All the same symptoms as yourself and almost all of us had a thermostat go bad.
1 - 10 of 10 Posts
