1 - 2 of 2 Posts
Can anyone help with finding the coolant temp sensor?
I the process of changing heater control valve, I inadverdently pulled a wire loose which has a female spade lug attached. It has to go to the temp sensor ,because the temp gauge stopped working. Can anyone help with where the sensor is located and how to get to it?
hdcran
Catera, ..
yes, it is under the intake mounted in the coolent bridge, between the heads in the back of the engine. The coolent temp sensor for the ECM is also mounted there. It may be easier to remove the filler panel from under the WS and look for it with a mirror. Just remove the wiper blade arms, mark blade location on the WS with a piece of masking tape for reassembly.
1 - 2 of 2 Posts
