1 - 2 of 2 Posts
I am wondering if there is a light somewhere under the hood that I do not see. My suburban has a light under the hood, and I think as much as the Caddy cost it should have one...my neighbor said that it doesn't have a light cause there is plenty light at the dealership where it is suppose to be worked on.
2003 Cadillac Escalade ESV
I believe the Under Hood Light was dropped in 2003. I am not sure as to the reasoning but it was probably a cost cutting measure. The Under Hood Light is kind of like the exhaust tip on the trucks. Some have them and some don't depending upon the year it was made and if it was the end of the model run.
If you want to add an Under Hood Light you should be able to pick one up with a mercury switch at any Auto Parts store. I believe on one of the GM Truck forums I have seen a post where someone added the 2002 Under Hood Light. Some dealerships might add it for you too.
1 - 2 of 2 Posts
