2016 CTS Sedan 2.0 T
just had an ignition coil go on the car at 91,xxx miles and noticed the front of the engine has a a lot of build up on it. Curious opinion and feedback if someone thinks I have a problem and should start searching the engine.
Motor vehicle Vehicle Automotive air manifold Automotive tire Automotive design
2019 XTS Luxury AWD, 2004 SRX N* AWD (gone)
To me that looks like oil seepage from the valve cover. Can get kind of messy (follows the law of gravity), but if your oil level stays about the same between changes you could wait to replace the valve cover gasket.
2014 Cadillac CTS-4 Performance
On my 2014 there is a little seepage right near the right hand side by the water pump, but nowhere else. I would more than likely think it is a leak with the RTV that is used to seal the front cover.
You might just want to use a torque wrench and tighten down all the front cover bolts. The torque spec for those fasteners is really low, so I can see them allowing some seepage over time. Personally I am going to retorque mine in the next month or so. I have no "liquid" oil on the outside of the cover, just discoloration like it happened at some point.
I will say that it is quite disconcerting to hear that coils are going out with less than 100k miles and less than 6 years on the engine.
Normally on direct ignition systems the coils are just fine for 150k-200k miles AT LEAST. Just sad that things have gotten to where they are at in manufacturing. I mean age is usually the big issue for ignition coil systems. Even then I have coils from a 2001 Acura that operate like new still at 230k miles. I also have ignition coil pack from a 2002 Mustang that were bad with only 79k miles and a 1996 Explorer that had only 42k miles with a bad coil pack. All OEM coils for reference.
Makes me wonder if it wouldn't be worthwhile to just pickup a set of MSD aftermarket coils to put on my 2014. I have no ignition issues as it stands, but why wait if they are prone to fail.
