I have a 2007 caddy CTS v6 3.6l, it has a bump to it while idling, opened the hood and took off the engine cover and the engine bumps too, I’ve researched a bit and seen it could be fuel injectors or my air filter, I ran fuel injector cleaner for about a month and nothing happened, I also took apart my air filter today thinking it could be dirt since I do have to travel down dirt roads quite often. And it still does it, I have no clue why or what to do to fix it, any help would be appreciated greatly!
The bumping may be a misfire.
Welcome Aboard !!!
An engine vibration is usually due to one or more cylinders misfiring ("miss") due to ignition or fuel mixture problems. Less frequently due to mechanical troubles, but then things are usually nasty noisy.
Have the car scanned at any parts store - it has its own built-in diagnostic system and, if something is wrong - one or more trouble codes will print out.
Use this to further decipher and post any found codes.
Welcome Aboard !!!
It’s not showing a check engine light will it still bring up a code?
08 STS 1SG HUD ACC F55 AWD, 08 STS 1SG Platinum HUD ACC F55 RWD
Your car can set many codes without setting the check engine light. Some less expensive readers only read some of the codes and some more expensive/specialized can read all of the codes. Some can even display each cylinder misses for this start cycle and/or average misses for the last 10 start cycles. This data would be very helpful to you in running down your problem. Good Luck and get the codes read.
Mine did this changed spark plugs went away runs smooth now
