Cadillac STS-V Black/Black
I just moved to Texas and unlike NY there are not many hills that require the use of the parking brake. In NY and in DE they don't even test them but here in Texas the parking brake gets tested and mine failed. Actually if failed really bad the brake barely holds the car still in reverse and not at all in drive. Is this a costly repair and is it common in the STS? Also I saw mention of an issue with the fuel pump on the STS-V will that effect my car? Thanks
2006 STS V Tango int
Most of the time it's just the parking brake cable out of adjustment.... It may different on our cars I can't remember exactly
06' STS V
You have to remove the rear brake rotors..it uses shoes inside them....a simple adjustment....search the forum
