1988 Brougham D'Elegance
Had a flat tire on driver rear of 88 Brougham. Jacked up car from rear frame and replaced flat with spare.
Am I correct in thinking as long as car is turned off, no damage can come to the electronic leveling system rear shocks and sensors while doing this.
Or, is there a way to turn off ELS when jacking up car which I am unaware of?
TIA for any input.
87 Brougham, 1969 Calais, 95 FWB, 07 SRX, 07 ESV
i know on the lincolns there is an off switch in the trunk but haven't seen one on any of my caddies.
Just jack it up. It's only Ford's air spring system that you need to turn off/disable.
In older cars the only possible damage would be for a height control connector rod to pop off one of the ball studs.
In ANY of these cars it's always a good idea to inspect the rear height sensor control rods whenever you pull a rear wheel - and all 4 wheels in the full CVRSS cars.
