1 - 20 of 22 Posts
2004 Deville
I am showing abs 1248 and 1214 codes in my 03 Deville. It is the ECBM. What part # is that , I would like to buy a used one and install it myself , is it hard to install ?
'98 STS (RIP @ 206,xxx miles)
WHOA. Make haste slowly when it comes to replacing modules. In the case of the EBCM your C1214 code is the cause of the C1248 code.
C1214 - System Relay Contact or Coil Circuit Open
C1248 - EBCM Turned the Red Brake Warning Indicator On
C1214 can be caused by corroded/oxidized/rusty pump motor ground connection. Double check the chassis ground connection for the black wire that exits the pump motor housing. Or maybe add a redundant chassis ground to a 2nd location.
No, it's not running. C1214 means the main power relay is inoperative.
ABS and TC are basically one in the same and controlled by the same pump.
Not quite.
ABS pulses the "driver applied" hydraulic pressure to the brake caliper at a wheel that is detected as spinning slower than expected. A pump is not required.
The Traction Control pump develops hydraulic pressure that is applied to the brake caliper on the drive wheel that is detected as spinning faster than expected.
ABS and Traction Control are mutually exclusive systems using the same module.
2004 Deville
Discussion Starter #11
Ground wire is perfect. Disconnected harness and cleaned. Codes and lights came back on ASAP . Can you replace the circuit board ?
2000 DTS 194,000 miles, 2000 DHS 203,000 miles
The most common problem with is EBCM is the relay inside it having broken solder points to the board. I have had several fixed for customers at work as well as my own by sending it into Myairbags.com. They will fix it and send it back to you within 24 hours of receiving it from you. Cost about 50 bucks plus shipping and has a lifetime warranty. You can even still drive the car with it removed.
1998 Cadillac Deville
And those codes are???
TCS C1234 DTC C1234 LR Wheel Speed Circuit Open or Shorted
TCS C1235 DTC C1235 RR Wheel Speed Circuit Open or Shorted
I figured it out... TCS Codes trigger the ABS and Traction Control lamps in the IC
Now Im still trying to figure out why....
you probably need two new rear hubs -
and you should have started your own thread -
rather than hijacking this one -
you need two new rear hubs -
Apologize to the OP for the Hijack but thank you for the Answer to my problem Basscatt
I think that would explain why my Cruise Control works so Sporadically too
1997 Deville, 89 Camaro, 07 Silverado
super....i have and had the same problem...i showed same codes...i replaced left rear hub and still have codes...i have been told that it is the ebcm module that is causing problem. mayb same 4 u
1 - 20 of 22 Posts
