That rather cryptic title may not have done my question justice. Here we go:
Let's say I have the heat set to 90 degrees. If I put the climate control system into LO, AUTO or HI, I can hear and feel the compressor engaging and disengaging, over and over, for as long as I keep it in those modes. If I use the ECON mode, of course it disengages the compressor, as it should.
I thought the compressor would only engage/disengage if it was needed? For example, if I have the defroster on, or if I need the air conditioning. Is this the way it's supposed to behave, running even with the heater on? My recollection of my father's 1986 Buick was that the compressor didn't engage if you had the heat on; you could leave it in AUTO (hence the term, "Auto").
Am I crazy?
Also, sometimes the heat won't come on unless I "trick" it: I have to engage the defroster, then switch to ECON. Otherwise, the fan will usually not begin blowing on its own. The air conditioning seems to work okay.
Any thoughts?
Am I crazy?
Any thoughts?
