1 - 20 of 54 Posts
98' Eldorado ESC
Having some issues now, after my accident it's been acting up, it's not a simple, oh the cars dead so let me jumpstart it, it's more erratic. A couple months back I was just driving crusing up a residential area when the car just shut off and came back to life, the whole dash went dark and I felt like the car died then just came back alive and the lights and everything worked again, it happened twice in 2 mins. After that I parked my car, came out to get something out of the trunk and it was dead(no lights, trunk wouldn't close) so I'm like ok let me go back in and finish watching tv( it was parked in a huge driveway and very secluded mountain area) I come back with jumper cables and I open the hood, my friend comes to jumpstart it but i turn around to hook the cables on but my lights were on, I run to the driver seat and it starts right up, but memory data was lost,(time, hvac, radio stations)
So for a bit it was fine but recently it's came back and more frequently, my dad and I were pushing it around our garage so the cables could reach our other car, as were pushing it forward i see everything come to life, key was in ignition, I jump in throw it in park and it started.
Yesterday the car died again, as im pulling out the other car for a jump start, I look over and see the lights come on, I run to the car and it's starts right up, AGAIN
This morning it started up normally, let It warm up and put it into drive as I give it some gas to pull onto the street it dies momentarily and starts working again and it jerked like a stick shift car when you dump the clutch while giving it too much gas, the car has died on me twice while going about 30 mph and twice when I'm merging onto traffic from a stop(usually first time I put it into drive) now I'm forced to stop driving the car for safety reasons, I'm still looking for another car but I need to keep this one running and driving for now. I thought it was the VATS but the theft system problem warning went away. Seems like an electrical issue.
Any help? And sorry for the long essay
· Master of the Dark Art of Diagnostics
Re: Electrical issues
sounds like a main power or main ground failure -
98' Eldorado ESC
Discussion Starter · #6 ·
Update:
When I unlock the car all the interior lights and headlight/tail lights turn on.
When key is in the sound comes on, I turn it to ignition and nothing happens, nothing makes a sound, no dash light up, gas/temp gauge. I try to turn it on and nothing happens, the only light that is on is the security light blinking cause the doors open. I lock the car and it honks the horn and locks the doors.
So is the battery gone? Ignition cylinder or the main power cables/ ground.
Update:
maybe - could be - possibly - worth checking out -
I agree. Also side terminal batteries have a habit of leaking battery acid out of the bolt holes, corroding the terminals, worse on DELCO batteries!
98' Eldorado ESC
Discussion Starter · #10 ·
Just tried to jump the car, wouldn't even start or change anything. Still completely dead, now I'm thinking it might be an ignition problem cause nothing happens when I turn the key into ignition. Car is completely dead. I'm gonna go talk to my dad's mechanic friend.
Said to check the fuses and get the battery tested
Checked the ignition fuse and it's fine, battery is up next later tonight
Why would you try to jump start it before removing the battery cables, cleaning both the cables and battery posts? Why would you ask for help and not check the simple things?
1 - 20 of 54 Posts
