1 - 8 of 8 Posts
does your headlight output get affected on your cads under full throttle?
mine seems to get affected under sudden heavy acceleration.
Does that mean i need a new battery? or a new alternator?
Happens to me as well brother. I just replaced the battery on my 94 seville STS and it STILL does it. My guess is that a BIGGER battery would remedy the problem. However, nothing is wrong w/ your car, don't worry about it. :)
I would sugest running your head lights though a relay that way you dont get the loss of juice from all the wires in the dash and the switch it self. you headlights will definently be brighter
Back in my drag racing days.....
Sometimes I would just watch the drags.
I would usually stand at the finish line.
Of course the drags were at night.
I could always tell when the race started because the headlights would get brighter.
I believe this is normal.
Pat
Discussion Starter · #7 ·
actually what i'm experiencing is total of opposite of your description
the head lights "should' get brighter with more RPM. With engine off the lights should be getting only about 12 volts if that because off loss through switches and wires, but with engine running and alternator generating output your voltage should be almost 14 volts (assuming no loss through switches and wires).
so my sugestion for finding out whats really going on is get a hold of a digital Volt meter.
1. take the negitive probe and ground it than check your batt volts first
2. turn head lights on with engine off and back probe the socket to find the volts of both high beam an low beam.
3. do the same now with engine running
4. do step 4 with some one holding throttle at a higher RPM
this will give you accual numbers to go off of
1 - 8 of 8 Posts
