1 - 12 of 12 Posts
I have a 1996 cadillac eldorado on my way home from work i seen the engone getting hotter then it got to hot and engine protection was turning on so i shut down the car and opened the hood i sene no sign of leak on the top so look under te car i see on the passanger side behind the wheel it all poured out have any ideas if a hose broke or what could of caused this i need to get this fixed as soon as possible i rather fix it my self if i know the problems an ideas please reply
Check the surge tank. They have been known to crack. I think the '96 is about where you said the leak was.
I think it is the passenger side wheel house on the '96.
Yes. the overflow line is connected to the surge tank as well as the purge line. It is where you put the coolant.
Discussion Starter #8
everything looks ok but how can i test it to see if its that tank any things i can do to test it?
Have the system pressurized. Watch for leaks while idling. Look for signes of dried Dex-Cool (whitish residue).
Discussion Starter #10
ranger i did the pressure test i found out so far its not a leak the tank is fine no cracks and the pressure test and no sign fo any leacks so its not a leack i also found out that where i tought it was leaking from it was the overflow line thwe enginge wa getting hot and ti was spilling on the overflow line after it over heated i put 2 gallows in the tank and 1 gallon in the thermostat what do you think is causing it to overheat and flip from the overlow line
1996 Deville (sold), 2000 Mustang GT
Yup, get the exhaust gas test done, like ranger said, it sounds very much like a blown headgasket.
1 - 12 of 12 Posts
