2001 Eldorado
Hi all,
My Cadillac Eldorado 2001 fuel gauge is not providing an accurate fuel quantity information. When the fuel deposit is half full, the fuel gauge, showing that is almost full of gas or the opposite - it is not accurate. Should I replace the whole fuel pump/floater or the fuel filter or the gauge itself only? The car has just 103,000 mile on.
Also, I was told that it might be not possible to buy a new fuel pump/floater, if that is the problem, since it is an old model.
Kind Regards,
Spyros
this is NOT an uncommon problem -
SOME have had success by adding a 20oz bottle of TECHRON fuel system cleaner -
MOST end up replacing the fuel pump assembly -
The problem is usually excess sulfur deposits on the level gauge resistance strip - see the pictures in the below link. The suggestion to try a jug of TECHRON is worthwhile as the stuff is supposed to eat those deposits.
Otherwise, it's fuel tank drop and pump assembly replacement. Here's a link to pumps - replace the whole unit as the pump itself is also on borrowed time.
Airtex, UltraPower, DELPHI, Spectrum, "AC Delco" (made by any of the foregoing) - all good choices. One or more brands may have an upgraded HD electrical connector that gets spliced into the wiring harness - wiring diagrams included. Click the INFO tab and look at the various pictures.
The fuel tank drop is NO fun.
I've also had sender issues. Upon disassembling the sender (nothing to do?), I've found not oxidation, but worn or broken slider fingers.
I simply reset the trip odometer, fill the tank, and when I reach 250-275, I'm almost out of gas.
Dropping the tank is a REAL PITA.
