Hello. Can you help me diagnose a fuel pump problem. After the car is hot, it runs eratically and stalls. Engine RPMs are going up and down. Ever had this happen?
Put a fuel pressure gauge on it and see what the pressure does when this happens.
Cadillac Eldorado
I have the exact problem with my '93 Eldo. Replaced FPR and it ran fine for a day or two. Now it won't start at all. Uncertain if the fuel pump even comes on. Trouble code P020 in history(open in fuel pump circuit). I had 8V at the pump fuse, shook the harness and got 12V. Still won't start. No time to look at it. Any info you got would be helpful.
Check the fuse. If OK, check the connector. If OK probably a bad pump would be my guess.
