I just wanted to share the information.
I have been having a knocking problem since I bought my 95 Sedan DeVille (4.9). I thought I needed some tune-ups. I have done many so-called basic tune-ups and even more, but I couldn't fix. Some of those repair made the car run better, but none got rid of the knocking problem...
Well, finally, I replaced the EGR valve and it fixed the problem! I am so happy.
No one here reported faulty EGR valve as far as I know, but it does break (not just clogged, but break). I had good vaccum right at the EGR valve, EGR solenoid was fine, I could activate the EGR valve by my finger to stall the engine at idle... So, I thought the EGR system including the valve was fine for long time. But finally I came to the conclusion that the EGR valve was not working properly, because there is no other reason I could think of! So I replaced the EGR valve. I had to grind a 13 mm socket to make it shorter to fit under the head of the valve to remove the bolts, but once the tool was ready, it was a simple job to do. After removal, I checked the valve. The EGR valve looked fine and seemed to work fine with my finger, but when I shaked it, it made funny noise in the head of the valve. Sounded like there were some pieces rattling in it. I don't know what they were. Anyway, since the valve looked OK except that rattling sound, I was wondering if it really fixed the problem. But it did.
I didn't know that 4.9 has such a wonderful acceleration and fuel economy!
