ECU replacement - misfire
941 Views 2 Replies 2 Participants Last post by  HeidiJ78
Hi. I recently replaced my ECU (it seems to have fixed the issues I was having - gas/temp gauge, key stuck in ignition, TC & Security light on) and now that I have the new one in, my car is running super rough. The diagnostics are showing a misfire at cylinder #5. I replaced the coil but it did nothing. It was recommended that I try replacing the spark plug, which I will do tomorrow. So my question is why would my car be running fine with the bad ECU and now that I have the new one I have a misfire? I even put the old one back on and the car runs fine. I'm hoping someone can help me make some sense of this. Thanks in advance.
If you put the old one on a it runs fine then it sure sounds like an ECU prob. It may have fixed your initial problems but created new ones.
Thank you. The more I think about it the more that's what my husband and myself are thinking. I'm going to call the company I got the ECU from and ask for a replacement. I'm thinking they coded it incorrectly and there really isn't a misfire. Just think it's coded wrong which is making the car run the way it is. Do you know if it can be re-flashed at my dealer even if it has already been? Thanks again.
