1 - 10 of 10 Posts
2004 Deville
2003 Deville , rebuilt EBCM , installed and ABS,BRAKE,TRACTION lights are still on . Getting the following codes
IPC U1000
MSM B2365
PCM P 1571
PCM P1644
PCM U 1040
SDM U 1000
What else could it be
Come on Bob... You been here long enough to know to post definitions... Don't forget History or Current. P codes set Ses light.
==========================:yeah:==:dammit: ===:rolleyes:
2010 DTS
Those don't look related. Brake & T/C lights should be accompanied by C (chassis) codes.
2004 Deville
IPC U1000 , class 2 communication malfunction
PCM P1571 , traction control torque request circuit
PCM P1644 , traction control delivered torque output circuit
PCM U1040 , loss of class 2 communications with ABS
SDM U1000 , invalid or missing data for primary ID
Are those current? Were those codes same before new unit and have you cleared the codes and see wht comes back?
2004 Deville
2003 deville with 160,000
Couldn't get the other thread back up
ABS BRAKE TRACTION all on. Sent EBCM out for rebuild. They said it seemed OK . Reinstalled and now the WBCM won't read . Following codes before and after reinstalling the ENCM .
2011 DTS Premium w/1SD | 1999 Deville Base (RIP @179K Miles)
Check if the connectors are clean, if they are, find a factory service manual and search for the wiring diagram for the EBTCM. Then test for continuity for each wire.
1 - 10 of 10 Posts
