2007 CTS-V
Is it possible?
I don't see a Volant intake listed anywhere specifically for the 06-07 model years, which leads me to believe that the 04-05 version will not be a direct bolt-on because of the different throttle body sizes. Can anyone lend some insight on that? Also, does anyone know if there is a way to make it work via some sort of reducer or other components?
Yes I know the $/performance ratio on any intake is pretty poor. I just happen to think it's the "cleanest" looking aftermarket intake available at the moment.
04 CTS-V with a little hp persuasion device
Its identical except you wont have the hole in the intake tube for the hose that runs to the passengers side valve cover. If you can drill and hole and make a little fitting then your golden. The different throttle bodies have the same OD so the tube will slide up on the 90 just fine. I have done it.
