i have a 92 cadillac deville 4.9l thats has been stalling very bad. I changed the ISC and the distributor because i was receiving the e41 code, after i reseted the codes the e41 code kept coming back even after i did the timing on the distributor. No one knows what can be wrong, the car seems to choke and turn off, specially when Im taking off and accelarating slowly. can someone please give me any suggestions before i burn this car down.
Look down the TB. See the two EGR tubes staring back at you? They should not be carboned closed. If they are, rod them out.
Not sure, but it is worth a try. Yours is not the same though. As mentioned in the other thread, you need to clean the "mouse holes".
