Blue 1993 Sedan DeVille, 4.9
After doing a tuneup on my caddy, I start getting the E39 code. Wasn't getting it before. I changed the ISC motor (was getting E30), plugs(got ac delco), wires, coil. I didn't put a new distributor cap or rotor on because they looked fine. What could be making the engine miss? Is the miss aslo related to the E39 code. By the way I also did not pass emissions here in Tennessee. Said my hyrocarbon level was 1181 and it should be 220 or less.
I think a miss will cause VSS problems. Do you think you have some crossed plug wires? I have only heard of one person getting rid of the E39 code but can't remember what he/she did but it may have been a tune up. You could try searching for E39 issues but I think your miss and high hydrocarbon level is causing it.
I was able to get rid of this code on my '91. Can't remember if it was changing the ISC motor or doing a second or third tuneup. Could the timing being off cause the hydrocarbon level to be that high?
1991 Sedan DeVille
I know this sounds crasy but it happens sometimes to the best of us. I recently did a full tune up on my 91' and I made the mistake of crossing two plug wires. Go back over the wires again if that doesnt work try cleaning out the throttle body.
1991 Sedan Deville
My '91 SDV has a bad fuel injector on cylinder #4. It ohms out very high (150K) compared to the other injectors (10 - 15 ohms). Consequently, I experience rough idle and while driving at certain RPM / throttle ranges, the car runs rough. I have no fault codes, however.
You may want to check the resistance through each of the fuel injectors. I believe the Haynes repair Manual has a diagram of the injector electrical harness in the chassis electrical system section. Make sure you follow the fuel system de-pressurization procedure, in case you decide to open or remove the fuel rail.
I'll be changing out the suspect injector on my car as soon as possible; I'll report my results afterwards.
Good luck and best regards.
I'll double check my wires. I have crossed them before on my '91 SDV. Pain in the butt.
I'm suspecting an injector is not working properly since I had a similar problem on my '91 before it caught on fire. Planned on replacing the injectors to get better gas mileage. Right now I just need to pass emissions by next week. Any tips anyone?
