1 - 2 of 2 Posts
93 Allante..04 CTS
Have a 90 Allante that was running rough and stalling when cold. Ran the OBD and got a E041 code for the cam sensor. Ended up replacing the distributor. Car is running fine now, went in to clear the code, it clears for about 10 seconds than comes back up again as E041 current. Any suggestions?
There is some kind of a problem with the cam sensor, the signal from it, or the distributor wiring. Another possibility is the ECM not seeing or processing the signal, or the wiring between the distributor and the ECM not passing the signal. What was the source of the distributor? The original distributor wiring harnesses seem to disintegrate with age. New ones are available, but are pretty expensive.
1 - 2 of 2 Posts
