Ok guys I took the car to the dyno this weekend for some baseline numbers before I turbo charge it. Now that I can control the air/fuel trim I wanted to experiment. Got some interesting results.
1st pull was running stock program. As expected the A/F was very rich(typical GM) at about 11.8:1 (251 HP, 252 torque).
2nd pull I backed off the fuel and it ran fairly lean at 13.8-14:1, but the HP and torque stayed nearly identical (250HP, 250T)
3rd pull I split the difference and got the fuel trim to 12.8:1 and as you can already guess the HP and Torque stayed the same. The guys at the dyno said they had only seen this happen with a Cobra Mustang running the 4.6l doubleoverhead cam motor. Very wierd. We did a final run unplugging the IAT sensor which made the computer think the air temp was -40 in hopes to increase the timing but the results were still the same.
The only other dyno results I have seen for the STS were from Corsa when they compared their exhaust with and without. Their results were 206 HP and 227 HP, so I am significantly higher than that.
Anybody have any thoughts as to how the HP does not change with a change in A/F ratio?
MARK 99STS
14.1 qtr. actual track time
http://www.markonemtg.com/marks99sts
MARK 99STS
