141 - 160 of 183 Posts
OK guys, it seems like there's a fix for everything, including the DVD issue. Problem is, I've got the '08 (well, not really a problem..) and I need to learn how to override the DVD system as well. Anyone crack the new one yet?
thanks,
Scott T
02' MP112 Grand Prix GTP
Isn't there a better way yet to get the DVD top play, instead of going through the whole preocess explained on the previous page? It would be a pain in the but once I'm cruising down the freeway and decide to pop a dvd in, but have to pull over on the side of the road to do the button trick first.
'06 Cadillac DTS
I managed to get the unlock code for my 2002 dts off of EBAY. I now have an '06 DTS and am looking for the same guy on EBAY....Pull up CTS unlock code or simply just pull up CTS in EBAY motors, scroll through and you will find the answer to your problems !
2007 Cadillac SRX V8
I did it! I found it!
I accidentally found how to get the PIN Code key touch pad on the 2007 model of Cadillac SRX.
It is Japanaese version, so it may look different on yours but try to do on the same way.
First, set DVD and watch it, and puch "Menu" botton like the picture below.
Second, select the "Disp Menu" (or something like that in English) Tag and Push and hold the left bottom of the screen for about 5 sec like the picture below.
Third, now the screen shows the Key Pad like the picture below!!!!!
HOWEVER!!! The key pad asks me 6DIGITS of the code!!!!!!!
Could someone help to find it???!!!!
So far, PIN CODE "295660" and "660" gives me some instesting Diagnostic mode.
But with this "660" code, you have to push and hold the power switch until the power goes down to return to the normal screen.
So, I think it doesn't have to be 6 digits since code 660 does something.
The Code 295660 also works on some Corvette and some Range Rover with Denso system.
http://forums.corvetteforum.com/showthread.php?t=1204336&page=19
http://www.rangerovers.net/forum/vi...start=15&sid=519ab8fe7fc1bf8787fd0b3df8b2545d
Here are the steps to be driving, riding, and watching (Be safe, if you are diving, do not watch screen!!)
# Step 1 Put in DVD.
# Step 2 Play DVD (Do not leave it at the front menu, if you do not start the DVD you will not be able to start it after you begin to drive.)
# Step 3 While playing - Hit the second from the bottom buttons on the right hand side of the DVD screen and then press the forward Seek Button. (You will see a little flicker)
NOTE: If you see a differnt screen with the words "cold reboot" on it, press the same button combination AGAIN and it should go back to the DVD...
# Step 4 Now disable the parking break and make sure that the DVD stays on.
# Step 5 Enjoy
If you did everything correct you will notice that all the features are disabled. If you are at the main menu of the dvd you will not be able to select play movie or any features.
If you would like to stop the dvd, you must hit the top right button first. Then it will bring up the safety lock if you are in motion or parking break off.
2008 SRX V8 AWD Sport
There is a device that does everything you want it to do. Play dvds, enter navigation info, and view your rear camera while driving. Its called a locpick. You can find it at www.coastaletech.com.
There is debate about whether or not the locpick works with the 07-08 SRX. Coastaltech has the absolute worst customer service so it is impossible to know unless someone wants to spend the $450 to find out. Let us know if you have. :rant2:
