1 - 8 of 8 Posts
Cadillac deVille sedan HT-68
Any problems to build a 2,5" dual exhaust system on a DeVille -68? It seemed to be tight at trannys crossmember and between frame and gastank. Where should the H-pipe be positioned? Is it enough with one muffler at each side?
Thankful for help.
/Peter
http://www.cardomain.com/ride/690250
Banned
1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
Are you going to build it yourself? Do you not have exhaust shops in Sweeden? 'Cause I'd just take it to an exhaust shop and say "make this exhaust system..."
Yes I'm going to build it by my self, is it so tight at the crossmember and tank? Do you have 2,5"? H-pipe?
And we have exhaust shop's here to :duck: but it'll cost me 800$ for a dual 2,5" with two mufflers...
1976 Fleetwood Brougham d'Elegance, 1990 Allante
I'm not sure how similar the two undercarriages are, but in my Fleetwood the H pipe is right at the back of the transmission. It is curved slightly towards the front of the car.
My mufflers are positioned in front of the gas tank. There is one on the outer edge of the undercarriage on each side.
I can try and get a diagram for you if you want.
I had dual, both mufflers just in front of the rear axle. Didn't have an H pipe though.
Discussion Starter · #6 ·
Thank's, do you have the aftermarket tranny crossmember I read about today? With extra space at the right side?
To be honest, I don't know. The car came with the exhaust it has, so I don't know what all went into it. I doubt it though - the exhaust components are the only things on the undercarriage that look new. I'll try and get a diagram of it up tonight.
Did they use the TH400 in 1968?
- Joe
I didn't, and really had no problems. The only time it scraped, was when I pulled into my driveway at an odd angle at speed. Even then, it was just a light scrape.
1 - 8 of 8 Posts
