1 - 20 of 27 Posts
1995 Cadillac Fleetwood, 1998 Cadillac Deville
Can a Dts OEM radio be installed in a 95 Fleetwood??? I was going to install a 98 Deville oem radio in the Fleetwood when I thought about going for the gusto and installing a DTS factory radio in it. Has anyone ever tried this or should I keep dreaming???
chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
as a direct bolt in? no. it looks too wide, and its not square, so you have to modify either it or the dash. you'd also need the harness for it , theftlock code (if GM still does that), plus you have to bypass the fleetwoods external amp/ tuner box. some GM radios even require the cars radio to link into the BCM/PCM.
Are there any options for a replacement factory radio on a 95 Fleetwood. I would like to replace the tape deck with another factory radio so I would have a AUX connection to install a ipod adapter. I have a long trip ahead of me in HOT June.
94 FWB 'Blue Devil', 95 FWB 'Black Beauty', 95 FWB 'Maroon Majesty', now 94 FW 'Bewitching Beige'
If your question is are there options - the answer is yes and they are relatively easy. If your question is there a non-fleetwood (read: non-B/D-Body) radio that will be relatively easy - the answer is no. First, you are in the fortunate position that your radio is NOT connected to the a data-bus or as Kevin said the BCM/PCM of the car. I would go after-market as there are a good number of Double-Din sized units (that's the size of the unit for 93-96 Fleetwoods) out there starting from a low of $250. You could doa google search or hit Amazon, Crutchfield, Sonicelectrix, etc. If you need more info - you can search the forum here where there are alot of answers.
Good looking out Barrister, I really don't want to go aftermarket. I guess I'll be the first to modify another ac delco to work in a Fleetwood. I'll do some more searching on the forum, but I really want the radio up top. That would be perfect to have CD, Ipod, XM radio and steering wheel controls, lol.
02 Escalade | 02 Corvette "Goldilocks" | 03 Blazer 4x4 | 92 Caprice Wagon LS1/T56
If you pull it off, you'd be pretty badass honestly.
But I can't see it without a lot of dash hacking going on. :( Good luck to you, sir.
Discussion Starter · #7 ·
I'm gonna hit Lowe's for a Dremer tool and go to work on that radio, lol. I've seen the 50 dollar wire to bypass the tuner box, so I might start there. Can I bypass the tuner box in the trunk all together and run my own wires??
I've heard of guys putting radios from higher end buicks circa 2000 in their fwb's. they look factoy (because they are), have CD and tape, and IIRC a 200 watt amp. you could always mod the radio to put an 1/8 inch jack into the outputs from the tape mechanism to the radio itself. I know it can be done on the 1.5 DIN radios as well as the old 2 post style, so I don't see why you can't do it on the newer radios. no dremel required, just a solder gun.
btw, you shouldn't need a $50 wire to bypass the tuner box. run new speaker lines, new ignition and constant power lines, and a ground to the new radio. its not hard, just time consuming. leave the tuner box as is in the trunk with power.
Discussion Starter · #10 ·
Show some picture, please. I need some motivation with this install. Anyone ever use the newer oem radios?? If so, please put some pictures up. That will help out alot.
06 STS-V, 06 DTS Performance - Past 91Broughamd'Elegance,76FWBd'Elegance,98STS,00Eldorado,06STS
I've put in a radio from a 1996 Buick lesabre into my 1991 Brougham(had some help from other members on here). It was relatively easy. Once I found the wire (color) chart for both cars, I was amazed how easy it was. The hardest part for me was getting to the amp inside the dash and disconnecting and removing the amp. I'm sure you can find a way to get that radio into your 95!
Discussion Starter · #19 ·
This is a picture of the back of the radio and the wire harness. I want to say the harness fits this radio. Someone correct me if I'm wrong, this harness does not connect to anything else besides the radio.
that harness is not for that radio. note the offset split in the harness plug, whereas the radio has a straight split. that harness is for a GM radio from the late 90's.
the databus will input into the radio through the harness. sometimes the databus (or ECM/PCM) communicate to the radio (sends it a signal that allows the radio to work- no signal=no radio), and sometimes they just provide power to the radio. If the radio receives a signal from the databus (and not just power), it will be a major ordeal to install (and costly) since you will have to install the computer from whatever car the radio came from in order for the radio to work, and even then it might not work.
How old is the radio you want to install?
1 - 20 of 27 Posts
