2006 DTS
I have a 2006 DTS that currently has both front turn signals, both front cornering lamps, both fog lamps, and both high beams out. The low beams, rear and side mirror turn signals, and running lights still work fine. All of the lights on the dash (fog and high beam) display properly with the exception of the rapid turn signal flash. It appears that all of the bulbs are good, and I couldn't locate a bad fuse in either the front or rear fuse block. Do all of these items share a common ground?? If so, where is it located? Any help would be greatly appreciated!
2006 DTS
Discussion Starter · #2 ·
It turned out that one of the three the wiring harnesses under the fuse box had come loose. It was the one closest to the windshield. I tightened the bolt on the top side of the fuse box and I was good to go!
I hade the same problem with my 2006 caddy DTS .I did as you recommended and it worked. I can not imagen what it would have cost me if it was not for you and this information. I'm grateful for your input .
Dieter
Hi I have the same issue on my 2006 Cadillac DTS the back blinkers on the tail light works the blinkers on the door mirrors works but the front orange lights or even my signal lights on the bottom of the bumper don't work I just want to know what caused that
