1 - 20 of 20 Posts
2006 DTS
Nice "Little" job. Ordered Seat Cover and Foam from GM Parts direct.
Tools Needed:
T50 Torx Bit
Flat Head Screwdriver(s) , Small and Large
Workbench (or in my case plastic garbage can)
Cover to protect Sill
Step 1 is to move the seat all the way forward , all the way down, using paper clip remove headrest
Step 2 is to carefully remove all the plastic trim from the front and sides of the seat. All connections are push in metal clips. Either trim removal tool or flat head to pry the clips and trim off.
Step 3 is to remove the Seat Airbag Fuse from the block under the rear seat
Step 4 is to remove (3) T50 Torx Bolts . (2) hold the seat in place at the rear. (1) Holds the Seat belt to the seat.
Step 5 is to lift the rear of the seat and push forward to unhook front seat hooks, then tilt seat back. Unhook Air bag Connector and Seat Power connector
2006 DTS
Discussion Starter #2
Re: Cadillac DTS Driver Seat Cover and Seat Foam Replacement Procedure
Step 6 is to Lift and tilt seat to fit under steering wheel and tilt on side IMG_2469.jpg IMG_2470.jpg IMG_2471.jpg
Step 7 is to Add protection to Sill plate and remove seat from vehicle.
Step 8 is to lift Seat assembly to workbench (in my case white trash " bench
Step 9 is to unhook side clips and rear plastic hooks from seat cover
2006 DTS
Step 10 is to remove foam and cover from frame.
Step 11 is to Clean Seat frame with All purpose cleaner
Step 11 is to take new Seat cover and foam and assemble on Bench. Turn Cover inside out to line up the Velcro in the cover to the Velcro in the foam. Side to side first then the center . Carefully push it in place and pull sides of cover tight over foam.
2006 DTS
Discussion Starter #4 (Edited)
Step 12 is to position the seat cover and foam assembly onto the frame and pull the rear attachments through the frame, tightly pulling the foam and cover against the seat back
Step 13 is to hook rear attachments to frame
Step 14 is to place seat on its side and make the hook attachments of the cover to the seat frame one side at a time. Use a flat head to push the plastic into place if needed. On the control panel side lift the cloath over the 2 metal hooks before securing the plastic clips in place. Then hook the remaining front of seat hooks to the frame.
Step 15 is to perform a reverse of every PITA step you took to detach the seat from the body, making the electrical connections, carefully reinserting all the push clips into the seat frame, securing the torx fasteners and replacing airbag fuse. Use a helper.
Step 16 is to admire the 78,000 Mile Caddy with the new seat bottom. It fells great to sit in.
Update: You feel the difference when you pull out of the driveway, doing straight, around corners bumps etc. Super new car feel change. Every bit as noticeable as the full suspension replacement I did last year, maybe more so. Mostly Side bolster support that disintegrates from entering and leaving the seat. Nice soft glove leather look and feel. Well worth the time and effort. About $160 for the parts.
2008 DTS Platinum. gone: 04 Deville, 76 Eldo conv, 74 Fltwd
Thanks, that will be useful as our cars get older and our butts bigger.
Where did you get the parts? $160 is a bargain compared to what I remember from GMpartsdirect, though I may be thinking of the full seat cover prices.
I've tried adding foam to the rectangular part of the cushion and subtracting that side bulge that digs into my thighs. I'm still getting some pinching from the bolsters, and I can't decide whether to cut foam off the sides or add more to the middle. I don't want more wrinkles in the leather or my head poking the ceiling.
Allow me to add my observations on seat cooler performance caused by cushion foam problems here:
https://www.cadillacforums.com/foru.../1083884-if-your-seat-cooler-heater-runs.html
I made an aborted attempt at switching cooler modules with the passenger seat because my side has switched off after a few hours, but it's difficult to reach the nuts that hold it on. There isn't much room for the socket wrench, extended or not, and my glasses kept falling off. I'm hoping the foam collapse was causing the shutdown, but it may be months before I take another long trip.
2006 DTS/2008 awd SRX V8
Excellent write up!
Very useful information here. This needs to be in the "sticky" section
As our vehicles get old, this will be a nice self repair to do.
Good Job, and thanks for the info.
2006 DTS
Discussion Starter #7 (Edited)
My mistake, the lowest price seller of the OEM parts was GM Parts Mania. Cushion 15216256 - 63$; Leather Seat Cover -Shale 15881952 - $84 + 19$ total shipping for both. The foam on my seat for a 2006 was made in August 2005 . 14 years is more than the Foam can stand up to . The difference in deflection between the old foam and the new foam is more than 50% (I measured the full displacement between a 10 Lb weight on the front corner old to new).
Best $160 mod ever! The new seat cover and foam makes the DTS scream "Im not old Im a 2019 Caddy"! Passenger and rear seats now have bottom envy :^) Although you will see the difference between the existing seat back and the new seat bottom when the seat is outside the car, you really don't notice it much when the seat is in car position day or night. IMHO it would be a waste of money for me to swap the seat back leather out.
Do you think it could be done without pulling the seat from the car? I suspect the side against the console might be hard to deal with, perhaps easier if the front and outboard side are detached first, and I haven't looked at how the cover is attached at the hinge area. Is that similar to the front?
Do you think the foam alone could be replaced without completely detaching the cover from the seat? That might all that some people need (or want) to do.
You might try a little saddle soap on the back cover to spiff it up. Removing it is probably a much bigger pain because of the side airbag.
We have the same recycling bin! Except mine is still covered in pollen.
2006 DTS
Discussion Starter #9 (Edited)
I gave plenty of thought to doing the job without removing the seat. Unless there is a real fancy trick that Upholstery shops use, it cant be done properly without removing the seat. Console is in the way of securing the RH clips. I installed a seat heater in my wife's Avalanche without removing the foam or seat, but that only required removing the clips at the front of seat and the outer clips and stuffing the heater pad between the foam and the cover..
In this case a lot more room for your hands to work. It worked ok, but the cover never fit the same as original afterwards. You need the foam out and on a table to fit the cover properly.
When installing, the seat foam and cover assembly is pulled tight into the bite line between the seat back and bottom and then the cloth of the seat cover has two clips that are clipped around a horizontal rod at the seat base..
Would be very very tough to do in car position.
2006 DTS perf
2006 DTS Performance Lux III
I replaced mine last year. I unbolted the seat but left it in the car. Just lay the seat back on the back seat. Much easier that way.
2006 DTS
Discussion Starter #12 (Edited)
Interesting method, cool that it worked for you. However, I hate working on my knees and wouldn't waste the effort and all the contortion involved in properly fitting the clips into place on the frame in the vehicle.
The superior ergonomics of having the seat frame and bite line at chest level to properly do the work made the 45 seconds to get the seat out and lifted to the white trash bench and the 45 seconds to put it back in the vehicle well worth the extra minute and a half.
Having it on the white trash bench made flipping it side to side to facilitate securing the cross car clips a breeze, but that did take like 5 extra seconds a side to flip it. Also, would not have liberally sprayed cleaner all over the top and bottom of the frame and mechanism if it was still in the vehicle.
Much easier to do it way I show in the procedure above, and I easily lifted it in and out by myself :^)
At GM we calculated that when an assembler enters or leans his or her body into a vehicle to install a part or parts, approximately 50% of his or her time was consumed in wasted effort due to the ergonomic disadvantage of leaning /kneeling etc. Building the DTS at DHAM you would very rarely would see an operator enter a vehicle to do work, and almost never would see someone working on knees. Chest height is nearly always :yup: the optimum work position.
1996 cadillac deville 2007 DTS Luxery 1.
I have been looking for a "cashmere" colored one for a while. Part # 15881968. Comes up discontinued. Any help Billdaman 1 ???? Ty , Tim 2007 DTS
2006 DTS
Discussion Starter #14
Im not completely sure about the Cashmere. I have a DK Cashmere Steering Wheel and Dash pad, but Shale colored seats. If you email those guys at the GM Parts depot with your VIN they can square you up with the part number. Most of the time an updated part number replaces rhe discontinued one.
I checked the sites I've been browsing lately, and all show it's been discontinued.
You can still get a passenger side one for non-heated seats:
https://www.gmpartsdirect.com/oem-p...mbz1kdHMmeT0yMDA2JnQ9YmFzZSZlPTQtNmwtdjgtZ2Fz
EDIT: this link goes to the seat back cover, not the cushion as it said on the diagram. I had a similar problem ordering the seat trim piece--the picture didn't match what the part number actually was.
I'd find a car with shale seats to see how different the color is.
2006 DTS perf
Im glad your way worked out for you. My way worked great for me. Took 20 minutes with no real effort.
2006 DTS
Discussion Starter #17
Omac say what, 20 minutes? Which part was 20 minutes and no effort?. Please post the details of the mechawizard procedure you used; I volunteer to post a time study :)
I would have difficulty getting the seat out of the car because I'm not a hulking he-man. Plus my glasses fall off when inverted.
2006 DTS Lux III, green silk/shale, bench seat!
Do you think the cushion could be replaced without replacing the leather? My leather appears to still be the original shape, it's just that the cushion is no longer firm. The leather for a heated shale seat is $217 for the part. Shipping is also a killer--$28 shipping for the cushion and an additional $12 if the leather is also shipped.
1 - 20 of 20 Posts
