STS-V 2007
Hello all,
I had replaced the Steering Sensor and I am now only getting this DTC C1283 and also the Service Stability System DIC message after a while of driving!!! Any ideas what could be the solution or the cause? Keep in mind that also I replaced all of the suspension including the front struts, mounts and spring coils, also the rear shuck absorbers and spring coils! Also I have bad tires and bad alignment.
I would appreciate your help.
Thanks,
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
nope
thats your steering wheel position sensor
im 100% on that, same thing happened with my dads 98 STS
STS-V 2007
umm, ok i will try to go back to the mechanic and check again. Thanks for your help.
