1 - 2 of 2 Posts
2007 CTS-V
Hello,
I recently purchased a 07 V. The owner installed a one piece driveshaft, which I decided to replace with the original 2 piece. I ordered a VC carrier bearing kit. I figured the flex couplers would be easy to find, but I cannot find anything for the front, and only the dorman for the rear, which got horrible reviews. I also need the hardware, does anyone have the coupler bolt and mount bracket bolt part numbers?
Thanks for any help. The threads I could find on this all seem to have outdated data.
· Administrator
'05 CTS-V
Only the V6 cars had a rear flex coupler / giubo - the V doesn't have a rear couple / giubo, only a front one. The OEM giubo for the CTS-V is SGF GAP01-003, as discussed here. I don't see them on Amazon anymore, but if you search for GAP01-003 you'll find the actual SGF part available on Ebay and elsewhere.
wholesalegmpartsonline.com has the part numbers for the mounting bolts. Not sure what you mean by "mount bracket". 2005 Cadillac CTS V 4DR PROP SHAFT
1 - 2 of 2 Posts
