OK, I promise, last question fo rtonight.
It started getting a bit cold here in California so I turned on the heater for the first since I bought the car. It blows cold (outside) temp air out of the driver's side, but the passenger's side gets a little warm.
I'd checked the heat when I bought the car a few months ago and it was fine. I've read all the posts on this site. I can see the passenger side acctuator moving (behind the little panel in the glovebox). I can't find the driver's side acctuator.
When I put the heater to defrost for the windshield hot air blows out of the passenger's side of the vent on top of the dash, but nothing on the driver's.
I should note that when I pulled codes it showed B1340 (Air Mix Door One Movement Fault) and B1341 (Air Mix Door Two Movement Fault). What do they indicate exactly and when should I go looking for the problem.
Also, I saw a post about a guy who's heater core became clogged by BarsLeak Gold. I recently had my radiator flushed and I add the Bars Leak Gold Label powder based on recommendations from this site. Should I flush the heater core? If so, how?
Are there other things I should be checking.
